Best center & surround speakers for Yamaha RX-V583 7.2 Channel AVR. Already have a pair of JBL Control 1
heraldthomas
Bengaluru
Dear All,
I bought a Yamaha RX-V583 7.2 Channel AVR for my 11 x 16 feet room. Now, I want to get the best surround effect out of my RX-V583 7.2 Channel AVR having below mentioned specs
  • --- 80 W per channel (6 ohms, 20 Hz-20 kHz, 0.09% THD, 2-ch driven)
  • --- 115 W per channel (6 ohms, 1 kHz, 0.9% THD, 1-ch driven)
  • --- 145 W per channel (6 ohms, 1 kHz, 10% THD, 1-ch driven)
Rated Output Power (1kHz, 1ch driven): 115 W (6 ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven): 80 W (6 ohms, 0.09% THD)
Maximum Effective Output Power (1kHz, 1ch driven) (JEITA) : 145 W (6 ohms, 10% THD)
Dynamic Power per Channel (8/6/4/2 ohms) : - / 140 / 170 / 190 W
I already have a pair of JBL Control 1. Please suggest best center & surround speakers which would get along with my JBL Control 1. The last thing which I would prefer is let go my JBL Control 1. However, I am ready to compromise on my JBL Control 1 if there are no other options left.
Best HT experience would be to use JBL control 1 for all 7 channels.. So instead of letting JBL control 1 go, make it better by adding more similar speakers for center, surrounds & heights..
isn't JBL Control one a powered speaker ? If so you can keep it separate and use it as an independent stereo with Aux cable. Get a good 5.1 speaker system that will go well with Yamaha. Try htstore.in, hifimart, sayhifi for 5.1 packages (polk, Taga etc depending on you budget)
Thank you, for the prompt reply. JBL Control one is not a powered speaker
