Best HTP under 30K
+1 to denom's suggestion. Also check Onkyo HT-S3500/3400 in less than 30K range. Both the models come with Passive sub woofer. Take audition and then decide the one that suits your taste. My personal preference in Onkyo as it has OSD, which is missing in Pioneer.
If you can increase the budget check Denon DHT-1312XP and Yamaha YHT-298.
Thank you denom and ukjeyaraj.
I Sort listed Onkyo HT-S3500/3400 and looking for best quote in coimbatore/tamil nadu.
I will update you both once i get the details.
I like to know best HTP under 30K
Thank you :)
Try JBL SCS-140BK speakers paired with Harmon Kardon AVR-134. I have been using this in my room for over 2 years and they are excellent value for money, and the sound imo is much better than Onkyo 3400, which I also have installed in one of the other rooms in my house.
I made my budget bit higher,
What about RS 32 Pioneer?
Good Choice. Stock available in Reliance Digital and EMI option is available
Please Advice.
Thank you :)
Have you checked the THD range, its "Maximum Power(6ohom/1KHz/10% THD/1ch)" whereas in Onkyo in less than 1%...So think before you buy Pioneer.
Forget the figures, go & demo first. Decide after demo.
Please Advice.
Thank you :)
Have you made your budget higher enough for separate components? If so your choice is going to be more. So spell out the new budget
