Best LED TV 40" to 43 "
sarge
india
Guys,
can you pls help me to select best LED TV with 40" to 43" , i am interested to buy plasma tv but its unavailable in kolkata.kindly suggest which model is best.
Everyone has different preferences when it comes to TV size or brands or connectivity & feature requirements....
Most running and good brands are LG, Samsung, Panasonic and VU.....would suggest you strongly check them out side by side with same channel yourself at an electronics store....explore the connectivity requirements...USB / HDMI, Headphones out, Audio out, etc. and decide based on your budget....most important is warranty and service.....
Bottom line fact for LCDs or LEDs ....they last between 3-5 years...there are cases where panels have failed after a year or two.
1. Budget?
Upto 55K
2. Display type and size?
40" to 43" LED FULL HD
3. Primary use of Tv/monitor?
FHD movies & Games.
4. Ports Required?
2 or more HDMIs and USB (is there anything else? )
5. Preferred choice of brand?
Sony, LG, Panasonic
6. Any TV/monitor in consideration?
Not Yet
7. Any other info that you want to share.
smart features & 3D if available.
Sony W80D series, 43W800D fits you perfectly and is a great FHD tv. Should be available between 55-60k. 58k on amazon on a quick look. must be cheaper in store.
Guys,
Whatever you choose pl buy extended warranty for two or more years as panel failure is frequent and that is most expensive part
