Best Portable Wireless PA system - Outdoor use
Red Liner
Hey guys,
I am looking for a wireless portable PA (public address system) with the intended usage being:
1. Will be used as a public address system to groups of 100 people for about 3 hours at one go (motivational talks etc)
2. Has to be ultra light (will be carried on flights to distant locations)
3. Has to be wireless - least amount of time spent on set-up, and less wires to worry about
4. An internal re-chargeable battery is a great bonus
5. Will only be used as a PA system and NOT for music. So I dont need an iPod dock or a sub.
6. Will be used both outdoors and indoors - but sound quality outdoors like in the hills or near a river for instance (in nature) should be very good
7. I dont mind importing this via Amazon - but getting something in India with warranty support would be nice
8. More the number of speakers (or the option to add more wireless speakers to the unit) the better, so that I can spread the sound around a largish group.
9. I can go upto about 25k INR on the budget. Maybe more if the unit is awesome. Price isnt much of a problem.
What do you guys recommend? Google searches are extremely iffy and I dont seem to find something that tallies everything I need.
I do hope this is the right spot for this question.
