Best router for home use.
RAJUSH26
pimpri
Hello friends ,
Which is the best and secure network router for home use.
I have a laptop and a Tata photon max net dongle , iPad with 3G and a HTC Smart phone .
Flat 1300 sq ft, 2 BHK. BUDGET NI LIMIT SECURITY AND SPEED R PRIORITIES , SHOULD BE ABLE TO USE TATA DONGLE
If wifi with tata dongle is all you require, go with a tp link mr 3020. It packs a punch for 1400 bucks. Suits the size of your flat when placed centrally. Its pocket able and can go around with you wherever you go. Delivers 150mbps n with wpa2 security. Its stable and a breeze to setup.
tapped on Note II cdma
It is a kind of question where Ten people will give you Ten different suggestions!! The best way probably is decide on your requirements and budget and then buy the most well known brand that you can afford.....maybe Linksys
Hello friends ,
You can go for MBRN3000 - Netgear.I'm using it .It is good and secured also.Check their compatability list for dongles before buying.
Friends, I have still not bought a router , at present which is the best router within 5000 , working on both bands and is SIM card and dongle compatible.
