surajts New Member Joined Jul 16, 2014 Messages 23 Points 3 Location Kerala,India Aug 20, 2020 #1 Hi which is best sound bar under 30 k
R Redflag Active Member Joined Feb 13, 2011 Messages 212 Points 28 Location Ludhiana Aug 22, 2020 #2 Yamaha Yas209
P prabhash Active Member Joined Aug 27, 2020 Messages 222 Points 43 Location Kolkata Aug 31, 2020 #3 I would say Q60r for around 26k
Passive_audio_enthusiast Well-Known Member Joined May 15, 2020 Messages 919 Points 93 Location Kerala Sep 1, 2020 #4 prabhash said: I would say Q60r for around 26k Click to expand... I was also pleasantly surprised to hear it sounding decent . But I haven’t heard anything else in it’s price range either.
raghupb Well-Known Member Joined Sep 11, 2015 Messages 3,309 Points 113 Location Bengaluru Sep 1, 2020 #5 surajts said: Hi which is best sound bar under 30 k Click to expand... Consider Polk Audio Magnifi Mini. It is not a soundbar per se (given the dimensions). But it sounds good for basic HT. Has HDMI-ARC, BT, OPT, WiFi/Ethernet, Aux and Google Cast. Cheers, Raghu
bipin1143 Active Member Joined Oct 7, 2019 Messages 297 Points 43 Location Guntur Sep 6, 2020 #6 Better go with 2.0 active speakers Soundbars are overrated imho Or else if you up your budget by 10-15k u can get a decent 5.1setup (used)
