Best speakers for YHT 2067
Vineethkmc
India
Hi all..I bought HTR 1810 with YHT 2067 reciever a few months ago.It is working fine , audio quality is fine.Now I am moving the hometheatre to a bit bigger room.I know that the speakers supplied are 30w each and the subwoofer is ? 50 watts.I would like to know the best possible configuration? (wattage per speakers and subwoofer) with YHT 2067.How high can i go in terms of wattage for satellite speakers and subwoofer without compromising audio quality/reciever/ speakers. I am talkibg about passive subwoofer and not planning to buy active subs.Thanks in advance
Look at the specs to find exact numbers but I use a similar setup , I bought boston a26 and mission mx3, both perform well and they are around 100watts
You should be fine with a 100-150watt speakers
for subwoofer if you are looking for passive ones just keep the yamaha , or buy an active one.
