Blown Fuse in Rotel RA-1520
saronoelle
Nagercoil
My amp rotel ra-1520 suddenly stopped working. The light around the power switch alone is working. So I opened and checked two fuses near the transformer is blown. Is it ok if i change only the fuse or it needs any service. Please advise.
Did you play it TOO LOUD for a long duration, by any chance?
If so, then it is ok to change fuses at your end. If not, then the amp requires 'some' look.
Typically the fuse change should be OK.. I recently had a catastrophy tooo ..but make sure the fuses are an exact match :)
Also whatever the Gurus above my comment said .. please follow em precisely .. and if theres no other damage or fault .. changing the fuse and getting back to listening to your music should be a piece a cake !!!!
