Blu Ray Dhamaka at Flipkart
Why do you say TS+ print is no match ? Any experience you would like to share ?
If we talk about the...
Picture Quality: Low Video bit rate in TS+; specially when they are adding more than 7 HD channels in a single Transponder of their Satellite.
Audio Quality: It's just Dolby Digital 5.1 audio and we all know that these DTH operators apply DRC on the channels' audio.
So...None of the DTH Operators' HD channels quality can match a BluRay !!
Well I never meant that it can be compared to a BluRay as we all know that 1080i and a full hd will have some differences. But to say " no match" is a bit harsh, as the quality of the PQ of tatasky+ is not that bad. Of course technically we can see there is a difference but practically I found the PQ good even while playing it on 100 " .
I agree to the fact that DTS hd and 1080 p is something tatasky does not provide.
These Titles (from flipcart - Excel Movies) are CBFC certified? If so they cut so many scenes which will spoil the movie experience.
true and gurranteed.. i will never buy any disk with that cert by F***Kers ..:o
unless the old comedy disks in 20-100Rs range
