Kumar442244
Hello fellow members. Hope you are doing great.
As the subject line suggest, m in the market for a bookshelf speaker within a budget of 50k to pair with Peachtree decco. Can stretch a bit if it's really worth it. Basically, looking for a warm sounding speaker which can pair well with bright natured class d amp. Looking for speakers with Sensitivity >=87 db and impedance 6 ohms. My current amp is Peachtree decco which is 120 WPC and is a class d amp.
Basically, looking for a clean mids with neutral highs. Should have decent bass. Not too keen on the bass division as will deploy a sub for it.
Open for moderately used items as well.
Currently using Dali zensor 3 which m finding a bit bright. Looking for an upgrade over z3.
Kindly flow in the suggestion.
Thanks in advance.
Thanks in advance.
