Hmm Mash I see the point. My only fear is experiencing a downgrade in sound which I am unable to check since I don't have an opportunity to audition my system vi's a vi's the bose side by side. Also in India they don't have the facility to buy the Bose on trial and return. So...
@sunster
How big is the new TV gonna be?
Will there be 4-6" free space on the sides?
Do you like your center and sub?
Would you consider replacing the AVR with say a slimline series from Marantz?
These are the questions looping thru your mind.
MA has 2 series - Mass, Radius
- FM
@drkrack can fill you in on Mass
- I can say Radius 45 was a pleasant surprise with Sub (good for movies, can deliver for music too)
Then there are Morel/ELAC/NHT as suggested by
@Naturelover
Cambridge audio also Minx
Check some of these out, at showroom or local FMs who may be willing to give you a listen.
You should get an idea of what they can bring to the game.
If these doesn't work out, Bose is always an option.
You may not get what you have, but keep your options and ears open for objective listening.
Raghu
