Buchardt E50
Nikhil
Moderator
Staff member
Hyderabad
A very interesting new speaker from Buchardt Audio
Link: https://buchardtaudio.com/collections/passive-speakers/products/e50
TECHNICAL SPECIFICATIONS
Operating principle2-way passive radiator system
Tweeter1 x 1" Custom Scanspeak textile dome with waveguide
Mid / woofer1 x 6.5" PURIFI Extended Stroke Driver with Ultra Low Distortion
Passive Radiator2 x 6" Extended Stroke low weight passive radiator
Impedance4 ohms
Sensitivity85 dB
Frequency response36 - 30.000 Hz +/- 3dB (in room bass response is most likely lower)
Crossover2000 Hz - 1st / 3nd order.
Minimum power recommendationSmall room: 45 watt, medium room: 75 watt, large room: 150+ watt. All into 4 ohm
Measurements (h x w x d)395 x 190 x 284 mm (15.5” x 7.5” x 11.1”)
Weight8.6 kg each
Speaker grillesBlack gills Included
Warranty10 years
Cabinet19 & 28mm (front baffle) solid european wood with internal bracing
Internal DampeningInternal scattering cutouts + Basotect® + Natural wool + Polyester
