Budget - 1 lakh for amp + 5.1 speakers
abhimanyuk81
Pune
  • Looking for suggestions for an amp + 5.1 speakers setup
  • To be used in the hall. Hall size is small to medium
  • Seating is pretty close to the speakers
  • Would prefer wall mounted speakers
  • Usage - 60% music & 40% - tv (sports channels + movies_
  • Amp should have wifi / bluetooth / internet radio capabilties
  • Looking for good sound quality and usually don't play it loudly.
  • Total budget for amp + speakers = 1 lakh
Thanking you in anticipation
You may consider Taga Harmony 607 5.0 Speaker package + Taga TSW90 Subwoofer + Yamaha V4A 5.2 AV Receiver
Can I suggest that you also consider the idea of a good pair of bookshelfs and amplifier ? I am suggesting since you mention a small room. A higher quality speaker might give you more listening pleasure. Or maybe even a 2.1 if you are willing to stretch a bit
If your usage is going to be music primarily then invest in a stereo setup , not 5.1. With your budget you will get a decent stereo setup whose sound will blow any 5.1 setup out of the water that’s twice it’s price.
Agree. At this budget, you can get a really good stereo setup.
5.1 setups at this price are pretty decent for movies, but will be poor for music playback.
Denon X 2300 and JBL / Polk audio speakers you may consider in your budget
