Budget External DACs vs. Yamaha AVR RX- V667
jagdish_p
Hyderabad
Will a DAC and Integrated Amp give substantial improvement over Yamaha AVR 667?
Some background Info from my end.
I have Mirage 550 series Floor Standers. I did not find a big difference in the following two scenarios.
a) Music (Flacs , High bit MP3s etc. ) stored on HDD routed through a media player --- HDMI digital out to Yamaha AVR 667 ( Stereo mode or Pure direct) to speakers
b) Music from Media player optical out to DAC Magic to Cambridge Azur 650A to speakers.
The improvement if any in Scenario b (Stereo set up) is very marginal. I attributed this to the speakers lack of response and am in the process of upgrading to Tannoy s
In the meantime I have given the Amp and DAC to my daughter who stays in Mumbai. Hence my new speakers will be driven by Yamaha 667 AVR .So my query to FMs is - Will there be a substantial improvement if I add a budget DAC?
Will any of the below budget (<200) DACs improve the SQ compared to the built in DAC of Yamaha 667?
a) Beresford Bushmaster DAC TC-7530DC
b) Tubemagic D2 by Maveric Audio
c) Arcam r Link
d) Higher budget Arcam r Dac
If you feel that there will be an improvement in SQ I will go ahead and place an order for a DAC.
Also what is your preference of DAC?
Did some reading on the net. ODAC is supposed to be bright sounding where as I prefer warm sound. Also does not have Optical in which I want. I am OK with not having USB in.
So amongst the remaining three DAcs from your list which one do you like?
1) Tubemagic D2 with upgrade
2) Beresford - TC7530 DC Bushaster (the latest model)
3) Teac UDH01-B D/A
3) Teac UDH01-B D/A
Both (2) and (3) will keep you satisfied for a long time. Get the one which is easier to buy/import.
Does the Maverick Audio DAC offer asynchronous USB please? I hear it is good value for money but wonder if it is being heard over S/PDIF (Coaxial) or Toslink (Optical) inputs only.
(off topic) This is an interesting article on USB inuputs and DACs:
USB audio - Synchronous/Asynchronous
3) Teac UDH01-B D/A
Thanks Santy. Teac is costlier then Bushmaster.
I see from your signature that you are using Caiman.
Have you heard Tubemagic and prefer Beresford over Tubemagic?
Interseting read. I am not very particular about USB capability as I will be feeding from a Media player.
So my question remains . Which of the two Tube Magic D2 or Beresford Bushmaster is better. How does the Music sound - Warm, Bright , neutral?
I heard Maverick D1 before buying Caiman since I felt it was better. Bushmaster is supposed to be even better. I have not heard D2. TEAC is at par with Caiman if not marginally better in resolution. I could not find any difference though. Note that Bushmaster does not have USB.
Did some more reading on the net.
Can I use any of the below DACs as input direct to a power Amp ( eliminate the pre Amp / Integrated Amp)
I have lsited my shortlist below - In increasing Price order
2) Teac UDH01-B D/A
3)Emotiva XDA-2 USB DAC
4) Arcam r Dac
What will be your recommendation for the best VFM DAC for warm low volume Music listening from above list?
Ok so do I still need an integrated amp or will power amp alone work with Tubemagic D2 or Teac UDH01-B D/A. The audio output of Tubemagic is only 2 volts. Also users have reported flat , low detail Sound when DAC is used as a preamp . Any first hand experience on this?
You need a preamp before power amp to use DAC.You can use Yamaha as pre & connect power amp though.Else integrated amp is fine.
Some DAC come with volume control & in built pre-amp,still dedicated sounds good to my ears.
2) Teac UDH01-B D/A
4) Arcam r Dac
Go for Arcam rDAC Rs.28,800 appx It has refined details and great sense of timing when switching from lower frequencies from higher or vise a verse .Clean and detailed :clapping:
