Budget HT system
m2maddy
Bengaluru - India
Folks,
I am trying to buy a decent budget home theater system for my Sony 47W850A TV which is setup in my living room.
The dimensions are 14x10.
My budget is around 20k but can goto max 28k if its really good.
However I need to have th system capable of playing Bluray disks as well as play external HDD movies as well.
Any good suggestions here.
There are very few options at your budget. IMHO Yamaha YHT-196 would be the best pick. Also check out Pioneer HTP-072.
BDP-Entry level with USB
Panasonic-BD 75
Philips BDP2100
Sony BDP-S1100
The Yamaha YHT-196 doesn't have in-built BluRay playing capability so I need to buy that extra as well, I need one device which does all.
I understand that the quality I get might not be great but a good decent one is what I need.
Also can I connect my D2H STB as Input to the HT System and from there connect to TV via HDMI ARC to get the full sound.
Here are few I looked at
LG BH7220 Home Theatre Systems | LG Electronics IN
BDV-E690 : Blu-ray Home Theatre Systems : Home Theatre System : Sony India
BDV-E3200 : Blu-ray Home Theatre Systems : Home Theatre System : Sony India
LG BH6330 Home Theater System |LG Electronics IN
Philips HTB5570D/94 - 5.1 Home theater
Philips HTB3570/94 - 5.1 Home theater
Maddy
Hi Maddy,
The systems suggested by you are HTiBs (Home Theatres in a box) and do not perform as well as a proper professional Home Theatre system like Yamaha / Onkyo / Denon / Etc.
These HTiBs will work well as they are compact and easy to setup. But the downside is that after 3 years or so, the PC board gets worn / burned out and spares are not easily available. The only option is to purchase another replacement unit which will cost more.
The entry level home theatres like Yamaha YHT 196 or 199 provide good performance for movies, music etc. As you increase your budget, you will get other brands...for example, I use a Marantz NR 1402 + Boston Acoustic 5.1 speakers ...this costed me around 48k last year. I added a Pioneer Blu Ray player BDP 150 costs 10k. The system is awesome. Ofcourse, I had to spend another 7k on speaker OFC wires, subwoofer cord, HDMI etc. A 1 TB external Hard Disk reads very well with no issues in performance or lag.
If you still want to go for HTiB, then I would recommend the LG model as the speakers and performance is awesome. You may want to check the extra devices connectivity options available.
Hope this helps.
Hi efernand1,
I agree that performance might not be top notch but it they work well for 5 years I could buy a new proper HT later on a new home and I thought it makes sense.
I will demo these once this weekend and check along with Yamaha.
Thanks for the suggestion.
A little late into the discussion, but what other moderators have missed highlighting is the AVR
If you buy a HTIB from a hifi brand -Yamaha, Onkyo - they have a AVR at the centre
When you go for a consumer electronics HTIB from Philips/Sony/LG, you do not get a AVR - the amplifier is combined with a dvd player.
The advantage of an AVR is multifold
- It has myriad connectivity options. You can connect all your devices - dvd player, Xbox/PS3/PS2, DTH box, any HTPC, media player like WD Live, a direct 3.5mm line in from your mobile phone, or connect a 2k Belkin bluetooth receiver. ALL of this (and more) can be connected to your AVR. And a single output goes to the TV and sound output from the speakers. In contrast, a consumer HTIB has maybe a 3.5mm input option at best and a USB port.
- It is modular. If one of your speakers go kaput, you can replace it with speakers of some other brand (if same is not available). AVR will work with most hifi speakers (assuming similar power). Or if your AVR goes kaput, you can replace AVR and old speakers will still work. But in consumer HTIB, if something goes kaput, entire unit has to be junked. And life of electronics is very unpredictable these days
- It is upgradeable. If every year you get some funds to upgrade, you can start replacing speakers 2 at a time. Or go for a more powerful AVR. One step at a time. In consumer HTIBs, step by step upgrade is impossible
So quality of sound being better notwithstanding, you should take a 4-5 year level view and seriously consider a budget Yamaha or Onkyo systems vs a consumer HTIB
grunthos,
This is a very interesting point indeed but if the HT does provide proper warranty then the overall amount would be still 26k vs 40k overall.
I agree that it has its own set of advantages but for me since I am testing out HT for the 1st time feel that to start this is a good way and when I go for 65inch TV I could get the proper full blown HT system.
But will keep these points in mind when I review these things.
Looks like you are looking for integrated 5.1 system like most consumers, which can play blu ray etc. In that case I will suggest the JBL one.
Was looking at it online and it is 300w compared to others at 1000w.
Wouldn't it matter much.
I guess I have to give it a demo to know the quality.
Any good demo audio files suggested to truly test the HT.
You can pick any Veer-Zara's songs for original 5.1 sound or pick any YRF's songs collections. Dil se's album is also in original 5.1 SQ you can also pick that :cheers:
Hi Maddy,
The Yamaha YHT 196 is available at Reliance Digital & Vijay Sales, Mumbai for 28K bundled with a Philips bluray player, just in case you want to consider that.
Hi m2maddy
Would suggest for the demo / audition to carry your own music CDs / Pen Drive and also movies...at the end of the day what you hear at home has to sound good on the system which you intend to buy....as for me, I carried a sample of all kinds of music including some action, drama, thriller movie clips....
