Budget upto 25-30k: DVDPlayer+Amplifier+2Speakers+Woofer
hencre
mumbai
hi,
I'm looking for a 2.1 speaker system to be used in my living room with LCD tv. After initial window shopping, my budget of 25k looks way tooo less :(
I dont want a 5.1 speaker system, because I cant wire the rear speakers.
What combinations of DVDPlayer+Amplifier+2Speakers+Woofer do you recommend in mumbai ?
Thanks for your help.
Hi:
DVDp CA DVD99 13k
Amp NAD 320/Marantz PM4001 10-12k (used)
Speakers Diamond 9.1 10-11k
Woofer MS SW150 price no idea
For the said budget,you can get good Htib from Philips starting from 12k to Onkyo 3200.
For music,
DVDp (3.5k) + Norge 2060(7500)+Norge spk(from 8k) + Norge sub(12?K) =31k
For music,
Norge make Sub? Last I saw was some 6 inch one! Not worthy of calling a subwoofer!!!
Also vinod are nad amps so cheap? also why require amp if you are suggesting powered speakers??
Thanks a ton for your responses.
I have now zeroed on:
1 -> Onkyo 3200 - ( any idea of the price in mumbai ?)
2 -> Yamaha NS P280 speakers+woofer (14k) + Norge 2060(7k) amp
3 -> Onkyo SKS-HT528 speakers+woofer + Norge 2060 amp
4 -> Sony Home theatre system(20-27k)
A. Which would best serve my purpose (HD Movies + IPod music Rock,Trance,Instrumental songs ) ?
B. Are there problems combining different vendors eg: Yamaha + Norg ?
If you cannot use rear speakers do not go for 5.1
Pioneer DVD + Norge 2060 + Wharfedale 9.1 or Polk TSi 100 + Polk Sub
With hard bargaining the above can be had for 30k.
Will sound better than all of the HTiBs or speakers from Yamaha/Onkyo
A. Which would best serve my purpose (Movies + Music Rock,Trance,Instrumental songs ) ?
Since your requirement is for 2.1 Speakers,
Try out Bose..
Companion 5 Multimedia Speaker System + Any good DVD player. all under 25k
Although it is meant for Computers, However the sound is pretty Amazing for Music.
Try out Bose..
no offence but lets keep bose out of this.u can get far better value in something like the audioengine A2/A5.very well reviewed equipment for precisely such usage.i have used a companion3 series2 2.1 and its quite good for nearfield usage,esp if ur using say a notebook.absolutely no value for the price tho.cheers
What cables do you recommend for connecting these?
Also Audioholics.com recommends these:
Cobalt Cables
Monster Cable Navajo
Sound King 12AWG
Whats a good place to buy cables in Mumbai?
