THERE ARE TWO WAYS TO GO ABOUT IT.
EITHER U BUY A HOME THEATRE PACKAGE WHICH IS EASY BECAUSE EVERYTHING IS MATCHED AND U STAIGHT AWAY AUDITION THE SET. EXAMPLE ONKYO 3500, 4505 DENON 1312XP, YAMAHA 196,296. U HAVE JUST TO ADD A DVD/BLURAY PLAYER IF REQUIED. SOME HAVE USB FOR MUSIC FILES. THE PRICE RANGES FROM 25000 TO 35000 DEPENDING ON THE MODEL AND UR BARGAINING SKILLS.
PL VISIT THE RESPECTIVE WEBSITES FOR DETAILS.
THERE ARE SEVERAL THREADS ON THESE SYSTEMS IN HFV.
IF U WANT TO GO IN FOR BETTER QUALITY STUFF THEN U CHOOSE THE COMPONENTS OF UR HT SETUP DEPENDING ON UR NEEDS AND BUDGET.
SEPARTE AVR,SPEAKERS AND SUB WOOFERS CAN BE MIXED AND MATCHED.
FOR EX I WOULD INDICATE
JAMO hts 426 SPEAKER . THIS IS A 5 SPEAKER TOWER SET UP. RS.21000 IN RELIANCE AND RS. 24000 WITH JAMO DEALERS
JAMO SUB 200 RS.15-16000
YAMAHA /DENON ENTRY LEVEL AVR AROUND 25000
SO FAR ABOUT 50-60000 U HAVE COMPLETE SYSTEM WHICH IS FAR BETTER THAN THE PRE PACKAGED SYSTEMS AND U WOULD NOT BE REQUIRED TO UPGRADE WITHIN FEW YEARS.
THIS IS AN EXAMPLE. HOWEVER MANY PEOPLE ARE SATISFIED PRE PACKAGED SYSTEM AS IT IS COMPACT AND TAKES OUT THE HASSLE OF CHOOSING A SYSTEM AND U KNOW WHAT U ARE GETTING. BUT SEPARATES DO PROVIDE BETTER QUALITY FOR MUSIC ALSO IF U BUY GOOD BOOKSHEKF OR TOWERS FOR THE FRONT TWO SPEAKERS.
IF U GO FOR SEPARATES U SHOULD BE WILLING TO INVEST A LOT OF TIME AND ENERGY IN AUDITIONING AMD BELIEVE ME THE JOUNEY IS AS PLEASURABLE AS THE END WHEN U PURCHASE THE SYSTEM.
JAMO
A
