hrd.hrishikesh
Hi guys,
I have ordered the UPA-2 power amp from Emotiva online. Expect to get it by second week of Aug. Am inclined to pair it with Paradigm Monitor 7 or 9 or Studio 60 (the monitors appear more VFM). This leaves the pre-amp and source. This is where I need some expert help. I'm now tight on budget and unable to spend on CDP and Preamp separates. So was thinking of putting together a PC for 2-channel solution using the Xonar Essence ST.
The trouble is that the input voltage levels for the Emotiva power amp are not mentioned in the manual. The Xonar has 2 Vrms max at line level. If I connect the line outs to the power amp, will the volume run at max all the time? Can I connect the headphone out of the Xonar to the input of the amp? If I go the way of PC + Xonar + power amp, would it be sufficient? I'd really like to avoid a preamp if I can right now.
I won't play movies on this PC, only stereo music. What lowest configuration can I use for the hardware to save money? If I must go for a preamp, what should I buy within 20K?
Thanks a lot for your help.
