buying a new home cinema
Denon - AV RECEIVERS
AVRX - 500- New
AV Surround Receiver. 110W x 5ch (6 Ohms), Dolby True HD, DTS HD Master Audio and Dolby Prologic llz. 4 HDMI inputs and 1 HDMI Out.3D Pass thru.
29,500
AVRX - 1000-New
AV Surround Receiver. 120W x 5ch (6 Ohms), Dolby True HD, DTS HD Master Audio and Dolby Prologic llz. 4 HDMI inputs and 1 HDMI Out.3D Pass thru.
41,250
AVRX - 2000- New
AV Surround Receiver. 125W x7ch (6 Ohms), Dolby True HD, DTS HD Master Audio and Dolby Prologic llz. 4 HDMI inputs and 1 HDMI Out.3D Pass thru.
55,900
AVRX - 3000- New
AV Surround Receiver. 315W x7ch (6 Ohms), Dolby True HD, DTS HD Master Audio and Dolby Prologic llz. 4 HDMI inputs and 2 HDMI Out.4K Vidieo Upscaling.
91,900
KEF UK PRICE LIST
Model
Descriptions
MRP (Rs.)
HTS 3001
Single Satellite Speaker of KHT 3005
15000
Q900 - NEW
Floor standing speakers
109000
Q700 - NEW
93000
Q500 - NEW
70000
Q600C- NEW
Centre Speaker
40000
Q200C- NEW
Centre Speaker
28000
Q800DS- NEW
Surround speakers
49000
Q400B- NEW
Power Subwoofer
43000
'C' Sries - C5 /pair
Floor Stander
40000
'C' Sries - C7 /pair
Floor Stander
51000
C' Sries - C6 /unit
Left Centre Right
14000
C' Sries - C4 /unit
Subwoofer
26000
R 200C / unit- NEW
Centre speaker
62000
R 600C / unit- NEW
Centre speaker
95000
R 500 / pair- NEW
165000
R 700 / pair- NEW
215000
R 900 / pair- NEW
316000
R 800/ pair- NEW
Surround speakers
115000
R 400 SUB /unit- NEW
Sub woofer
99000
Reference Series
R201 / 2 / pair
Reference Book shelf speakers
390000
R202 / 2C / unit
Reference Centre Speaker
250000
R203 / 2 / pair
Reference Floor standing speakers
570000
R204 / 2C / unit
375000
R205 / 2 / pair
750000
R207 / 2 / pair
1300000
R206 / 2DS / pair
Reference Surround Speakers
450000
REF 208 / unit
Reference subwoofer
475000
REF 209 / unit
Reference - powered subwoofers
978000
POLK USA SPEAKERS PRICE LIST
Model
Descriptions
MRP (Rs.)
LSI SERIES
Lsi M707 Tower / pair
3-Way, 5 speaker, 300W, 88 dB, 8 Ohm Tower Speaker
240000
Lsi M705 Tower / pair
3-Way, 5 speaker, 250W, 88 dB, 8 Ohm Tower Speaker
198000
LSi M703 Bookshelf /pair
3-Way, 3 Speaker 200W, 88 dB, 8 Ohm, Book-Shelf Speaker
96000
Lsi M706C Center / unit
3-Way, 4 speaker, 250W, 88 dB, 8 Ohm, Center Speaker
71000
Lsi M704C Center / unit
3-Way, 4 speaker, 200W, 88 dB, 8 Ohm, Center Speaker
51000
LSi M702fx Surround / pair
Bipolar, 240W, 88 dB,8 ohm, Surround Speaker
97000
RTi SERIES
RTi A9 Tower / pair
3-Way, 6 Speakers, 500W, 90 dB, 8 Ohm Tower Speaker
99000
RTi A7 Tower / pair
3-Way, 4 Speakers, 300W, 89 dB, 8 Ohm Tower Speaker
68000
RTi A5 Tower / pair
2-Way, 3 Speakers, 250W, 90 dB, 8 Ohm Tower Speaker
56000
CSi A6 Center / unit
2-Way, 3 Speakers, 200W, 90 dB, 8 Ohm Center Speaker
28000
CSi A4Center /unit
2-Way, 3 Speakers, 180W, 89 dB, 8 Ohm Center Speaker
18000
FXi A6 Surround
Bipolar, 125W, 89 dB, 8 ohm, Surround Speaker
34000
Fxi A4 Surround
Bipolar, 150W, 88 dB, 8 ohm, Surround Speaker
27000
DSW PRO 660 WI - NEW
Powered Subwoofer
40000
DSW PRO 550WI- NEW
Powered Subwoofer
34000
PWSK1 - NEW
Wirelss Subwoofer Kit
12000
MONITOR SERIES
TSx 330T / pair -New
Tower speakers
30000
TSx 440T / pair - New
Tower speakers
39000
TSx 550T / pair - New
Tower speakers
62000
TSx 250C / unit - New
Centre speaker
20000
TSx 150C / unit - New
Centre speaker
12000
PSW125 12" Subwoofer
260W, 12" Woofer, Powered Subwoofer
24000
PSW110 10" Subwoofer
100W, 10" Woofer, Powered Subwoofer
18500
OWM 5 / unit
Surround speaker
12000
RM SERIES
TL600 - NEW
Home Theatre Speaker system (Black Stone)
42000
0
Hi jsb
If you are looking out for some feedback on the Marantz 6007 or 6008...go for it...worth its value and performance for music and movies....in terms of speakers you need to look for speakers with the same impedance as the AVR.....most important, you need to ensure that the sensitivity levels are 88db or more...this will ensure good output even from low powered AVRs.....the heart of any home theare is the centre speaker and subwoofer...these both need to be of excellent quality...the fronts and rears are just passengers in a home theatre setup to provide support and effects....in music mode...this is where your Front speakers would matter and hence need to have the required dynamics to fulfil your music appeal!
Speakers which can deliver almost or rather all frequencies continuously (20hz to 20khz) are ideal....you can click on my user name for related posts which can guide you to some extent...also a search on Home Theatre systems in HFV would help....
All the best....it all depends on what appeals to you and your budget..
@efernand1
thanx
some more info
budget can be stretched to 3 lacs
have been advised for marantz paired with klipsch referrence series rf 62 with klipsch sub sw112
any thoughts on whether this is best available
looking for movies mainly with killer punch--5.1 setup
any thoughts on any thought on psb or magnat series--whether they are better
With a budget of 300k, you should consider pre pro and power combos. That said, I'm using a Marantz SR 5007 for nearly an year and have no complaints.
The Klipschs are very aggresive speakers and would work nicely in a HT setup. For subs look at SVS and Def Tech.
views on
marantz 6007 or 6008---70k
jamo 626 hcs 3--68k
klipsch sw 112 subwoofer--71k
@jsb... I think you have spent at-least sometime in this forum before posting this query... If you have seen ppl who have queries, they give the requirements with their room size, and seek guidance on what they are looking for...
It would also be good if you can update this speaker prices in the Price list thread, so other FM who are looking for it would benefit...
Appreciate if you could give some more details on requirements, so other fellow FM can pitch in with their suggestions...
@elangoas
easier said than done
there are so many brands
the moment u decide on one model someone always pitches in that abc will beat ur choice
cutting to the chase identified
qacoustics 7000
kef 2005.2(does the 5 mean these are from the year 2005--what are the present equals)
dali zensor 1 5.1
tannoy hts 101
receiver yamaha 673
can somebody say what will be best in
bookshelf system 5.1
floorstanding fronts with satl 5.1
can we have a model in each segment where there are no arguments about sound and killer bass
No no jsb.. you have far better options at that price level. Dont stick only to Klipsch.
A different opinion, JBL have got studio grade speakers at that level, pls checkout.. Also, do audition BnW, TAGA, MK sounds, Theils etc..
cotacted mk sound
the mk sound 150 thx is for 10lacs
the m7 or mp7 series is for 3.2lacs
Hi jsb
In terms of AVRs, you should consider one of the following brands only as they live up to their reputation in performance and delivery of stated output across all frequencies besides the added features.... Cambridge Audio / Marantz / Nad
B&W speakers 600 series or CM series blend very well with Marantz AVRs, the Polk RTi series also are good....you can also look at Wharfedale Diamond series. Subwoofer can be of Velodyne or SVS......end of the day...speakers need to be of almost the same impedance of the AVR, the sensitivity level should be 88db or more...higher the better output and less strain on the AVR. The most important the speakers need to deliver the required quality and punch in music and movies across all stated frequencies smoothly...time for you to go with your favourite music and movies and audition as many speakers you can and then shortlist what appeals to you in terms of performance, looks and budget.
Hope this helps...
