[Buying Advice] Blu Ray Burner and media
Sarath_
BD Burner:​
Help me choose which Blu Ray Burner to buy. Unfortunately I don't even know what choices I have and am completely in the dark about them.
Requirements:
BD Burner
SPEED: Doesn't matter, but faster the better for obvious reasons
BRAND: Any good ones [Sony, LG, Samsung, Pioneer etc] Anything.
BUDGET: As low as possible. Definitely below 9k
Open to buying online or locally. Kindly post any links you find online.
Extra Points:
~The burner will be used mainly for burning HD videos, although I know that this information has no bearing on the choice of burners
~I have no interest in extra features, if there are any and would like to save on them
#I already have a DVD writer in 2 PCs
#One of them is even lightscribe capable so I have no interest in it too
BD Media:​
In my search for the past week, I have realised that BD-R are hard to come by. Hence kindly suggest any source of blank media online. I will also be scouting locally for the same.
Criteria:
Quality is more important than the price here.
Preferably with superior coating than normal BD-Rs
In case you have any suggestions about good media or have used any good quality ones then you are welcome to share it here.
~Price no bar. But do bear in mind that my last names don't fall into Mallya, Tata, Ambani, Birla; either of these.
Currenlty looking at:
~Verbatim
(found nothing else)
