turntablist
Dear FMs,
Please see the current list of equipment I own. I love the sound I get from these but it's upgrade time.
I got this equipment after a lot of advice & help from FMs and it served me really really good. So I am back for more :*
Want to buy my dream subwoofer. Will spend atleast 1 Lakh, will prefer to spend 1.2L but will spend 1.5L if needed.
AVR: Marantz SR6012
Front L/R: Crystal Acoustics TX-T3SE-BL
Center channel: KEF Q600C
Front Heights: Polk Audio OWM5 pair
Rear Surrounds: KEF Q800DS pair
Please ignore the room measurements as I do not own an apartment and live in rented houses. Will buy a house after 2/3 years, so lets just focus on the sub for now
My requirements:
1. Sound quality: Want highly detailed, controlled & smooth bass. Not over the top & definitely not boomy or jarred. It definitely needs to go to 20 Hz or lower. I do not want to miss out on anything,
2. Looks: Want high quality piano black finish, a better design (rather than a dumb looking box) will be awesome
3. One or 2 Subs: I want to buy one high end sub rather buy 2 mid range subs (this is almost final unless someone can very very strongly convince me otherwise).
Contention, please clarify:I have 2 full range towers which go down to 33 Hz. I have been using them for almost 2 years now, no subwoofer needed. So, if I buy a hugely capable subwoofer like the Arendal, do I really need 2 subwoofers because I will have 2 small subwoofers (my L/R towers) & the full power sub...
4. Usage: 50/50 for music/ movies
5. Other Req: I dont even know what to look for, so please help me out here, what to check before buying
My Shortlist, in order of preference:
1. Arendal Sound Subwoofer 2 or subwoofer 3: Looks awesome & has enough power, more than I will ever need
have a look: https://arendalsound.eu/1723-thx-series/1723-subwoofer-3/
2. B&W PV1D: Looks awesome but will it have the oomph?
3. Some Rhythmik Subwoofer: IDK which one but heard a lot of praise for them
4. SVS SB/PB-2000 PRO: Very sceptical about this one. Everyone says that the Arendal sound beats the SB-4000 in performance. So, this should be a no-brainer actually
So, please suggest:
1. A place in Bangalore where I can audition these/other subwoofers
2. Which subwoofer do you advise, even if you have a suggestion outside of this list
3. Any other advice
I just love this forum. Thanks a lot for you much needed advice. I know a lot of it is coming :-D
AVR: Marantz SR6012
My requirements:
So, please suggest:
3. Any other advice
