Cambridge Audio - Azur 351 A - Integrated Amplifier +Dali Zensor 1 Speakers
ajitelsy
Kerala
Hi,Need some help with this setup Cambridge Audio 315 Amp with Dali Zensor 1 speakers will be using it with my laptop FLAc files cost 56K for both.Should I go for it at this price point would not mind spending 10k more for something better.
I have not heard this combo though but recently got Norge 2060 with Wharfedale Diamond 9.1 which is very very good for indian music and overall setup came in 30K. However depending on your music preference the combo may be different. Also unless you own a costly macbook, I woiuld say go for an USB dac like ODAC in sub 10K range or Arcam / Schiit / etc usb dacs in 10K+ < 20K range. You will end up with a far better sound. However Dali Zensor seris is a very good and capable set of speakers. But if you want to spend on stereo alone then you can also look at Quad combos
Dali Zensor 1 (I have Zensor 7 -5.1 pkg including Zensor 1 pair which i use for surround) is very good speakers.
BUT i suggest check new version Zensor 3 which is launch last month And far better than Zensor 1 for stereo music
Check Dali Web for full details & Awards..
Price Rs.33,000/-Mrp..
Rajubhai
Thanks,I have a audioengine dac which i use with my laptop quite good could you suggest some quad combos they are quite expensive.
And far better than Zensor 1 for stereo music.check Dali Web for full
details & Awards..Price Rs.33,000/-Mrp..
Rajubhai
Thanks,Read a review about the Dali 3 but could you tell me where it is available in india.
Contact Mr Pravin...Vipul Audio Chennai...
Mob 09941476667...Tell him you got ref from Rajubhai Mumbai.
He will def help you...
Rajubhai
