jayantadak
I just downloaded a few dts audio files. It was 1.41 GB in all. It played well in my PC through the VLC player, KMplayer, GOM player. Next I copied these files on external hard disc and tried to play it through WDTV live media player, but WDTV failed to recognize the files at all, leave aside playing it off. I browsed through the file managment, there too the files were not found. Only the cover of the album was found in the jpg section.
Is there any way playing these files through the WDTV LIVE.
For the perusal of our forum users I have noted the codecs while playing it via the VLC which are as follows:
Type: Audio
Codec: DTS Audio (dts)
Sample rate: 4800 Hz
Bitrate : 1536 Kb/s
JAYANT
Type: Audio
Bitrate : 1536 Kb/s
JAYANT
