Car safety hammer
skul82
Pune
I am looking for a good car safety hammer to keep in my car in case of emergency. Basic functions required are only two, breaking window and cutting seat belts. There are a lot of products available online on Snapdeal and Ebay. If you are using anything please share the details.
1. Snapdeal -
Speedwav - 5 in 1 Car Emergency Tool with Hammer, LED Flashlight, Safety Belt Cutter, Magnet Surface & Torch - Buy Car Accessories Accessories | Snapdeal.com
Is anyone using this, by the looks of it I am not sure if it is strong enough to handle the swing force.
2. ebay -
4 IN 1 Family Safety CAR Tire Pressure Gauge Seat Belt Cutter Torch Hammer | eBay
3. Teknobay -
TEKNOBAY
This looks good, but not sure where to buy it.
Thanks,
Sushant
I am using the one shown on snapdeal. It is available much cheaper on ebay-
car hammer | eBay
Regarding the review I would say it is as advertised. The torch is good. The beacon works well. Cutter worked fine on a paper I tried. The magnet can be used to place the product on roof or the boot.
Havent tried the hammer yet (Thank God :) )
car hammer | eBay
Thanks Sanchit, Does it also have Alarm/Siren kind of thing?
Good that you didn't need to use the hammer thing yet :) though I wonder whether it is actually strong enough in case we need to use it.
It has a beacon. But no audible alarm or siren.
God forbid if you have to break window sometime you can probably use this-
In case, one does not have a hammer, the seat headrests can be used to break the windshield or the windows. Just pull them out and hit the glass with the metal part of the head rest. Another technique is to hit/ push the windshield with your feet. The windshield in most cars is just pasted and a strong hit from the legs should be enough to displace them.
Also, many cars, mostly non-premium ones can still be open from inside manually even if there is an electrical failure or central locking failure.
