Cart - Light fit vs Tight fit
Nice post...
will try this once my cart and phono stage burn in process completes
regards
Tanoj
I don't know about light or tight fit but if one is careless enough to fit it loosely that the cartridge can move about slightly (as I once did carelessly), you will get rubbish sound and scratch your head endlessly trying to figure out what's wrong:lol:
BTW, after lots of trials and errors, my method is of fitting cartridge is to finger tighten the nuts, then give it a slight final twist with a nose plier to make it firm without gripping it too much. Earlier I used to make it a point to give even the final twist by finger (in my misguided attempt to be a purist), but sometimes it becomes loose in the longer run (despite looking tight at the time of tightening).
I understand that cartridge should not be too loose or too tight. It should be just tight
