Hi All, I am currently using Dali Rubicon LCR as Front LH/RH, could not afford ( very expensive) Rubicon Vokal ( center) my query is
- is it mandatory to use same brand, series for center also ( currently I am using Custom made center speaker)
- what will I miss if other brand is used as center, I understand mostly only dialogues are delivered from center & not much more
- for Surround I use SVS Elevation
I will be greatful if any one suggest any alternative for center in lieu of Rubicon Vokal (center) in the range of ₹ 20-25K
Thanks !
Thanks !
