soumyajit92
Hi guys, looking for budget 3D glasses for my epson tw9300 projector since the first party option is kinda expensive considering i may need 4-5 pieces.
In AVforums they have mentioned "Any glasses that are fully compliant with the "Full HD 3D RF standard" from 2013 or later should work.
I use the Samsung SSG-5100 because they relatively cheap and they work perfectly.
See details in link below."
Or
Epson TW9400/7400 information
These works, Original 3D Glasses SSG-5100GB 5150G for Samsung 4K UHD Smart TV JU7100 H7150 8806085510555 | eBay Cheers Tommowww.avforums.com
I have Sainsonic 3d glasses 4 of them. Used to work fine with Benq HT 3050 1080p Projector. I will have to check whether they work with 4k Epson Projector. Ping me if anyone is interested
Thanks identified the problem its stupid battery which i bought was not good bought a new Panasonic CR2025 battery and the 3d worked.Ok i managed got 2 pair of Samsung SSG5100 glasses from OLX but i can't test it . I have only Nvidia Shield pro has a source and when i tried to play 3D content from youtube shield is not recognising the 3D signal. Some suggests to bring down the resolution to 1080p n check... Yet to try.. if someone has tried to play 3d content through shield pls help
How much did you pay for it? Will be useful for me to know how to price itOk i managed got 2 pair of Samsung SSG5100 glasses from OLX but i can't test it
5K negotiate but make sure you the glasses are on or after 2013How much did you pay for it? Will be useful for me to know how to price it
