S Sopra Member Joined Jan 3, 2021 Messages 99 Points 18 Location India Aug 28, 2024 #1 Hello All, I seem to have damaged the leads from the cartridge to the tonearm. Can I solder this back?
R reignofchaos Well-Known Member Joined May 12, 2008 Messages 3,019 Points 113 Location Bangalore Aug 28, 2024 #2 Yes just make sure you use silver solder (wbt is good) and don't put too much of it.
G G401fan Well-Known Member Joined Nov 26, 2008 Messages 507 Points 63 Location Mumbai Aug 28, 2024 #3 Sopra said: Hello All, I seem to have damaged the leads from the cartridge to the tonearm. Can I solder this back? Click to expand... Solder the wire to the cartridge clip after detaching the clip from the cartridge. If attached, your cartridge will go kaput.
