HeadElastico
Hello everyone,
This is my first post here. Just to give you some background - I am moving houses soon and am want to set up my AV systems in the room.
Now, I do not know anything about the audio video space and hence thought I would reach out to the experts here! This is my setup:-
I want to setup the home theater in my bedroom. The dimensions are fairly small (~10x13). I plan on using a 42 inch 4K/UHD TV.
I have a PS4 console, a Tata Sky and a Laptop. Basically, I would like to have a 5.1 system with all of these seamlessly connected to my system. Aside from this, I would like to play music from my phone/ipod, preferrably wirelessly and have it play directly through my speakers.
Now, I have read about AV receivers, HTIB's, etc. and it is quite overwhelming, to be honest.
I am looking to keep the budget to about 25-30k. In this budget, I believe HTIB's would be the best bet, but can someone please guide me on how to go about this?
Key Requirements:-
1.) Easy connectivity to my devices with me being able to play music directly over wifi or bluetooth
2.) I want the entire setup to be 4k ready
3.) I am not an audiophile; obviously I want the setup to sound good, but I am not looking for bleeding edge sound as I probably wouldn't recognize it, even if it hit me
4.) Require a fairly compact system; can compromise on power since it is a small room, so being able to shake my neighbours floor isn't a priority
Keeping this in mind, please suggest how I should go about this. Should i buy an AV receiver and get 5.1 speakers separately, or does an HTIB make the most sense? If so, please suggest which one would be the best fit for me.
Help is greatly appreciated.
Key Requirements:-
