Hey
Long time lurker here. Decided to make an account and ask for some advice.
I have a media room. Wanted to upgrade the audio in it and was thinking of getting a pair of active bookshelf speakers that could be hooked up to both my desktop and the TV in it. Was eyeing the Edifier S3000 Pro at around 50k. Not sure if that is overkill or not for my requirements. Currently using the TV as is without anything and Audeze iems for my desktop.
Some additional info:
- Budget ~55k
- Room Size is about 11 x 11 feet.
- Room has no open area leading into a hall or kitchen. It's a repurposed bedroom.
- Room has a tiny itx pc hooked up to a monitor + a 55" tv with a firestick 4k. Use the desktop for gaming and to listen to spotify/youtube/podcasts. Sit on the couch and use the TV when watching something on netflix etc.
- Distance between the couch and the TV is around 8 feet.
- Most of my content consumed is via Netflix 4k / Amazon Prime / Twitch and the occasional Kodi.
- Desktop is also connected via HDMI to the TV for playing some games on the bigger screen
- Type of media consumed: On the desktop during workhours it's mostly music/podcasts. On the TV during leisure time it's a 60/40 split between tv Shows and movies. So I guess I'd want something that is overall good but if I had to choose then something that sounds great for video content would be great.
- Type of music genres heard: EDM/Rock/Country/Hip hop and Pop
So given my requirements. Is the Edifier S3000 Pro a good overall choice? Or is it overkill?
I've tried to google and there's a lot of conflicting info:
- People suggest getting a used AVR + passive bookshelf speakers instead which can be upgraded later down the line [Which I know nothing about]
- Active speakers like the one I was looking at [S3000] are apparently only good for around ~ 4ft/5ft of distance. Any further and the sound quality is lackluster? Is this true?
- Will not having a sub by going for a bookshelf speaker ruin immersion in movies? Especially given the distance from the TV/speakers when on the couch
- Am I better off just getting a soundbar with a subwoofer for the tv + a cheaper nearfield bookshelf for the desktop use?
I've also added a rough layout of my room in case that makes a difference.
Looking forward to hearing your suggestions on what I should get.
Thanks!
- Budget ~55k
Thanks!
