connecting Denon X 2000 to wifi
Nickhill007
Pune
Hello All,
I have wifi across my house i need to connect my ethernet enabled DENON X 2000 to the wifi. I cant use a ethernet cable as the distance between my router and Denon is high. I prefer using a WIFI bridge set up please suggest some cheaper options for the same. Router is Belkin N600Dual Band. I itend to stream 1080p movies from my NAS drive. Links from ebay flipkart would help. :signthankspin::sos:
