Connecting new speakers to an old receiver
leesaf
Cambridge, MA
BACKGROUND:
Hi all, first post. I have a simple question about hooking up newer speakers to an older receiver, but no amount of searching has turned up any answers (either my question is too obvious or I am searching the wrong things). But consistently I am seeing people in this forum with good answers to other questions, so I am hoping I can tap into the collective knowledge here.
I had a Pioneer VSX-D814 Receiver that I was using to power two RCA bookshelf speakers and a sub. It is primarily used for a turntable, but the other day I was running my computer audio through it and had the computer volume too low and the stereo up too high, something popped, smoke came out and I assume that is the end of the Pioneer, at least until I get it in for someone to look at.
In the interim, I have an old Fisher 160-T that I would love to hook up, but I cant figure out the connections.
ACTUAL QUESTION:
Each speaker has a + and - terminal, which has the end of a speaker wire in it. However, when I get to the back of the Fisher 160, I only see one terminal for each speaker. (See attached photo). Starting with just the right speaker, if I contact just one end of the speaker wire on the right speaker main terminal, nothing happens. Same if I twist the two ends together and put them both around the main. I get some sound if I hook the one around main and one around com, but it is very distorted, as if it is coming from under water. I also tried one end of the speaker wire around the left speaker main and one around the right speaker main, which made the same distorted sound plus sparks.
So I am at a loss. I think that I do not understand why the speaker has a + and a - terminal, is one a ground and do I need to do something else with it? This was very easy with the Pioneer when I had two 5-way connectors for each speaker, but if you roll me back to a machine from 1968 with much less going on in the back, I am less sure of what to do.
Any insight to what I am doing wrong would be appreciated, since this Fisher 160 really is a beauty and I would love to get it playing some music to see what it sounds like.
Thanks!
I am assuming that it would've got a mono input using the RCA cable.
I ain't sure of hooking the dual wire, but I would try to make a Stereo to RCA cable (DIY) & connect the free ends with the speakers + & -wire ends!
Can you please post Higher ersolution pics ?
These pics just pixelise when I zoom into them, so Impossible to read.
Alternately, take a close up of the rear panel near the speaker terminals .....
Sorry, I didn't realize that those images would be scaled. Uploading via imageshack now.
I feel lost having to ask such stupid questions so I hope you put up me. We all have to start somewhere. :roll eyes:
Isn't an RCA cable the one with a plug on one end? I don't know how you would attach that since the terminal on the back of the Fisher is screw. Or is there a version of an RCA that pre-dates the plug version that shows up here when I do a google image search of "stereo to mono rca cable"?
Got to see the clear images now - felt nostalgic.The old fisher looks great and I am sure it will output good sound.
Connections for Speakers:
Connect the left speaker + Ve wire to the main left terminal on the Fisher at the rear and the -Ve wire from speaker to the common left terminal on the Fischer. You do not need any connectors. Just remove the insulation from the speaker wires to expose the copper and use a screw driver to connect on the Fisher tuner. Be careful and ensure that no loose wire strands from +Ve and - ve touch each other or any other metal part except the terminal.
Do the same for the right speaker.
How are you connecting your computer output to the Fisher receiver?
I think they should be connected to the Aux input at the rear.
Also let us know the speaker model or specifications to check compatibility with Fischer
Thanks for that explanation. I did that and am still not getting any sound out of my speakers, so I think I am going to take the receiver into a repair shop and see if I can get someone who knows more than I do to take a look at it.
