craftel Speakers
kaptan
chennai
Anybody using Craftel speakers for 5.1 surround sound. Hook with AVR.
I have Pioneer AVR. Looking for speakers. Craftel will be a good option. I dont know about it please let me know if anybody knows or used it.
Thanx
Thanx
Hi Kaptan,
If you are looking @ branded speakers, @ your budget, i would like to recommend you PSB Alpha Series. Contact Raghu @ Deibel, Cenotaph Road, Chennai. You can get BS speakers (2.0) first and then start to build your system as & when your budget allows. This is the best way to build it.
So you are looking for centre, surrounds and sub?
Get the centre from MS range. It is said that it is better to match the centre with your front speakers.
You can look around and add surrounds and sub later from other brands that you like.
