Cropping your fav movie scenes
Love4sound
Chennai
Hi All
I have DTS HD and atmos movies and would like to know if there is any software available that could crop without affecting the actual audio and video format?
BTW, you might get more replies and suggestions if you mentioned exactly what you want to do and why.
Do you want to reduce the dimensions or extract clips?
So I figured.
I use and love Solveigmm to split and join videos. Very precise split. No idea if it affects DTS sound though.
I see their Christmas discount offer is still on until the 27th.
So I figured.
Ok will check it out. M particular that the Audio format is not affected.Not every day I get time to watch a complete movie so wen I get 30-50 mins of time I watch some of my fav action scenes but very annoying to forward nd rewind.
This is to crop the dimensions right? I want to crop the fav scenes of the movies I watch like action sequence and save them as a clip
If you use kodi for watching movies then the bookmark feature may actually be very useful for you to save specific points within a movie and this way duplication in form of clips is not required
https://kodi.wiki/view/Bookmarks_and_chapters
Ok I use my Blu Ray player so won’t be able to use kodi. May be in the future wen I upgrade for some device like Nvidia Shield it a 4 k player that supports kodi I will check this out. Ty
