I currently have a phillips cd 165 player(audio only) bought it around 10-12 ( maybe more ) years back. I also have a standard philllips dvd 642k used for movies and mp3
I recently bought a norge 2060 and millenium speakers and I am happy with it :clapping:
Now the cd 165 player is much better than the dvd player for obvious reasons (audio cd's) . I have been reading for quite some time that one can buy a DAC or perhaps buy a good CDP ( good is relative but something I can afford and sounds good say like marantz 5003)
Eitherways before I decide to upgrade want to know how good or bad my current CDP is from the specs. I ask this as if I want to arrive at a go/no-go decision only after being reassured it will indeed make a difference ( has to be substantial as this implies a sizable investment )
If I am indeed living in pre-historic ages and the marantz's / DAC's are far better then an upgrade is essential.
CD 165 specs are as follows:
Number of channels 2
Output Voltage 2Vrms +- 3 dB
Output resistance 1 K
Dynamic Range (-60dB) min 85 dB from 20 Hz- 20 KHz
Channel Separation min 82 dB from 20 Hz- 20 KHz
Signal To Noise Ratio min 90dB from 20 Hz- 20 KHz
Freq Response +/- .55dB from 20 Hz- 20 KHz
Phase Linearity +/- 7.0 20 Hz- 16KHz
automatic switched de-emphasis with time constants 15/50 Us
Outband attenuation min 35dB above 40kZ
Please provide your feedback on the overall query.
