D dakota New Member Joined Apr 16, 2017 Messages 10 Points 3 Location Noida Sep 7, 2017 #1 I am planning to buy a DAC for Sennheiser HD451/ ATH M50x. Please advise if I should go for Fiio e17k Aspen2 or Fiio e10k (or any other?).
M marsilians Well-Known Member Joined Dec 8, 2008 Messages 2,605 Points 83 Location 117.192.87.109 Sep 7, 2017 #2 Any reason other than cost you are not trying out the x3ii? I don't own the 17 but listened with my AKG 701 and still preferred the X3. It's also way more versatile DAP
A akstorm Member Joined Feb 12, 2016 Messages 94 Points 18 Location Bangalore Sep 7, 2017 #3 Are you looking for a portable or a mobile setup? Let us know your needs and then we can suggest better options. Also what is your budget and source?
anubisX Well-Known Member Joined Apr 11, 2009 Messages 968 Points 83 Location Wonderland Sep 7, 2017 #4 Schiit Fulla 2 or Audioquest Dragonfly
D dakota New Member Joined Apr 16, 2017 Messages 10 Points 3 Location Noida Sep 7, 2017 #5 akstorm said: Are you looking for a portable or a mobile setup? Let us know your needs and then we can suggest better options. Also what is your budget and source? Click to expand... My budget is 5k (to 8k max). Primary source would be my PC/MacBook. What do you mean by portable or mobile setup?
D dakota New Member Joined Apr 16, 2017 Messages 10 Points 3 Location Noida Sep 7, 2017 #6 Forgot to mention, I am also open to buying pre-owned gear.
MaSh Well-Known Member Joined Oct 12, 2012 Messages 3,849 Points 113 Location Bangalore Sep 7, 2017 #7 dakota said: I am planning to buy a DAC for Sennheiser HD451/ ATH M50x. Please advise if I should go for Fiio e17k Aspen2 or Fiio e10k (or any other?). Click to expand... e10k has some really good reviews online, although I have not heard it myself. My hunt for a DAC ended just a few days back. Some of the links that I had saved from OLX: NuForce Icon HDP Headphone Amplifier Audioquest dragonfly black MaSh
