kishanvkumar
Folks,
Need help here. Almost finalizing on my HT setup with Dali Zensor 5 speakers. Need suggestion on the subwoofer. The setup is for 70% movies and 30% music. The room size is 11 by 19, but I am currently using the 11 ft side. So the HT setup will be in 11 by 12 area and the rest is open.
Was able to Demo Dali EF12 along with Zensor 5's. They sounded pretty good and packed a punch. But somehow for sub woofers i was dreaming of owning velodynes The Eq Max 10 is in the same range as Dali at around 45K. It is already a stretch and this is the absolute max i can go.
Not able to get Demo of Eq max 10, heard Impact 12 at Htstore Bangalore, but somehow the setup was not right and did not have any Bass. So need help on deciding. SVS and Sunfire were quoted in the 55K range and out of my budget. Are there any other I should consider in the 40K-45K range?
Between Eq Max 10 and Dali EF12 which would be good? Do they need to match with speakers? since speakers are dali's would it be good to choose Woofer from same timber?
Thanks for the help.
