Im not sure if this is the right subforum or not, but if it is not, apologies.
(If somebody could guide me to the correct one, that would be great)
I have a ProCinema 600 5.1 setup with a Yamaha RXV-1500 I use along with my PS3.
I have 2 issues:
1. Noise from one of the speakers, especially at higher volumes (when there is something like an orchestra playing, as the volume goes up to the crescendo, you hear chatter like noise coming from the surround left speaker.) Its like radio noise, but to the tune of music.
2. The ProSub 600 is an Active Subwoofer (turns itself on and off) and is connected to the LFE out by rca cable from the Yamaha receiver to the subwoofer. The speakers are connected directly from the receiver. The issue is that I can see the subwoofer is on (red led glows) but then, there is no sound coming out of the subwoofer (even when I can hear audio out of the other channels).. EVER. not once so far. (it was definitely working sometime earlier, before i shifted houses). I cant hear any broken/loose parts dangling when I lift the speaker on its side so I don't think its damage/broken.
Is there any check/ troubleshooting I can do to solve these issues/ run diagnostics?
I live in mumbai, where the only deftech service point is in andheri and I stay quite far away, so trying to exhaust all possible options before I send it in.
I have 2 issues:
