Denon 1713 or 1913?
I don't know about online stores which sales them, but you can contact SEN & PANDIT ELECTRONICS PVT LTD in Kolkata. They are in this business for a long time and reputable.
Voltage stabilisers - automatic relay operated as well as manually controlled, precision servo controlled voltage stabilisers - single phase as well as three phase versions, constant voltage transformer (cvt) Manufacturer & Supplier,SEN & PANDIT ELEC
For this kind of electronic appliance you better buy it from local store so that in case of problem you can claim warranty.
Thanks a lot Rupam.
It is 22 lb wt. So planning to take it as check in (either put it inside a suitcase or as a separate package) depending on my final buys
I would suggest you add another layer of padding to the box-- either with towels or bubble wrap
Any additional charge by Airlines? if we check in as handle carefully piece? any idea about it. and did you inquire about warranty issue if we buy from here?
