Greetings!!
Need your help,I understand it boils down to my choice and what i have personally auditioned, however appreciate experienced senior's thoughts
Am looking at setting up a system at my place and being a newbie, am slightly confused
My Requirements are
1) 40% soothing country music ( to be run in dining area) - thinking 2 FS
2) 40% party music (both dining and drawing room to be used) thinking of adding another FS pair here
3) 20% movies
The sound to be warm and not loud
http://s7.postimage.org/qdfrqgqqz/delhi.jpg
A) The room size is ~600 ft ( 20 x 32), and i am looking at primarily for music. Should i go for 2 FS in front and 2 FS at the back ( since the length is slightly high)?
B) I had gone through web and saw the wharf-dale diamond series, the 10.5 looked decent as well as the Tannoy Mercury V5. Can you provide your thoughts on speakers
C) Am confused between the following
i Denon 1713/1913/2113
ii Yamaha 473/573
iii Pioneer 822/922/1022
iv Marantz
d) do i need an Sub - if yes which one. I had the end of room as the placement for Sub
Budget for FS + System to be 100k ( can budge slightly)
Thanks for all your help and please pardon my ignorance
My Requirements are
3) 20% movies
ii Yamaha 473/573
iv Marantz
