Denon x1200 vs x2200
Go for - Denon AVR X2200W
See the differences here:
AV Receivers
Also, search the forum for all the information you need before you start a new thread. In case you are not able to to find what you need, take help from google/bing.
Is it worth upgrade from Yamaha 3067 to Denon x2200w in terms of wattage , i having jamo s426 towers .
To me its like comparing 25k product with 50K+
I have heard x1200 & x2200 many times in different speaker configuration, to me x2200 sounded more punchy than x1200. Difference is so visible if you play a song in both with similar speakers/setup, you will jump to x2200 if your budget allows you.
But if you are not looking for specifically 7.1, then you can look at Marantz and Pioneer as well.
Pioneer 830 (5.2 ch) is another AVR which contains almost every feature which normally comes in High End AVRs. Audition it if you can to experience.
hope this helps.
