Hi all,
My current desktop 2.1s are a bit on and off and while I am looking to fix them, am wondering if it is not time to look at something better.
So, am looking to put together a plug-and-play active 2.1 (or can do a good active stereo pair first and add a good sub later) with the two main criteria being:
1. Neutral stereo pair for good vocal clarity at around half a metre, which will very occasionally go up to one metre, and
2. A good package sub or a standalone one for great, clean, true bass. The sub will also be placed very close by, but can definitely give it some breathing room.
A majority of the listening I do at the desk are simply interviews, podcasts, and proper hip-hop bangers when working. Nothing else.
I see the Edifiers come highly recommended around here, and the Genlecs, too, but the latter may be out of my budget. What are some of the other companies I should be looking up?
Also, I currently just connect the speakers to the headphone jack in the comp. Is there anything I should keep in mind if I change systems?
Would be very grateful for any other recommendations, including left-field or funky
Thanks and regards
Thanks and regards
