superczar
- Joined
- Feb 5, 2008
- Messages
- 834
- Points
- 93
Highly unlikely to be an issue with NF/PrimeI use a denon 2400 with Dali z3,vokal and Z1. While watching netflix and amazon prime contents i also get a distorted sound. Even even while listening to music with Bluetooth or spotify. To explain the sound it will be like a crackling sound especially at high notes. But while listening to the same songs in you tube or the movies that have this noise in netflix and prime dont produce this noice in bluray content. So i finalized it is an issue with source and content and moved on.
Don't forget that Millions of people use them worldwide with no SQ issues (Including I)
It is in all likelihood a problem with the way your streaming setup is feeding data into your AVR
Your streaming setup ideally needs to bitstream the untouched audio stream to your AVR
Unfortunately the myriad possible combinations of AV setups make it difficult to trubleshoot
Add to it the the problem of TVs managing the audio stream (for those who use ARC) as different TV models and even diff series for the same brand use differing terms & names for the Audio settings.
The problem that the OP has however seems a little odd as the NR1609 should easily be able to drive the speakers
I am not sure if the NR1609 has straight RCA Pre-in but if it does, testing via that should be able to tell if the issue is with the amp or pre-processing
