DNM Amplfier
I liked the Hifi amp with all in one CDp & DNM speakers.They sound true VFM.Check it tomorrow.
I own a DNM 5.1 system (AV455?) with their PACE speaker and subwoofer , it is absolutely brilliant, good VFM , it has been around 6 years now, bought directly from their sakinaka based factory (one mr.dilip bajaj), till now its working perfect.great sound for the money you are paying
I have a DNM stereo amp that can deliver 100 watts per channel at 8 ohms. It is mated to Sonodyne Sonus 2605 speakers and the CD player is a Cambridge Audio CD4. Although the CD output is really good, this amp has limited equalizing options. There is a loud switch that increases the bass but the entire music sounds like it is on steroids. The front panel (the manual switches) is not working any more although I can't say it has been badly handled. The remote is downright cheap. I paid about 12 K for the amp but would say it is better to go for used CA or NAD amps, if available. The finesse and quality would be a lot better. I bet their USB port won't work after a few months of usage.
Which model do you own? Is it the A-777?
I have listened to their hig h end amplifier and CDP with all in one unit with their own speakers. Clean sounding. I would rate them above Yamaha AX 496 with which I campared it side by side.The high end amp does not have tone controls/right left balance/even the brand name on it. It is kind of stereo power amp with gain control and multiple inputs. The speakers were good too. However speakers had 'made in china' label on back! When I asked Mr. Bajaj about it, he told me he has manufacturing unit in China to save cost. Now that is difficult for me to believe. The products are VFM (especially products named high end). but I would buy them if I am sure not to get 'upgraditis'. Resale value won't be good.
Specs of the tube amp should include tubes used, else other details are of not much use. Also from the specs it seems its a push-pull amp but cannot conclude by looking at the images. I think the pre-amp is transistor / op-amp and only the output stage is tube.
Hi am using dnm vaccum tube amplifier with paradigm monitor 7 speakers I tell u guys it sound better than any 150 w integrated amps believe me it is one of its class amp...
