Manish Sharma
Sorry if i am asking an absurd question…I jus wanna know do I need a power amp if my AVR has class D amplification…I cudnt get the real specs of the amp section of my Pioneer SC-LX-87 AVR but in their manual following is written -
Amplifier Section-
Multi Channel simultaneous power output (1 khz, 1%, 8 ohm)
9 ch total …………….850w
Rated power output (1 khz, 4ohm, 1%, 1 ch Driven) ……………….260w
Rated power output (1khz, 6ohm, 1%, 1 ch Driven) ………………………..220w
Total Harmonic Distortion ………….0.04% (1khz, 130w + 130w, 8ohm)
Speakers used are-
- Front LR - QAcoustics 3050i Tower (91db sensitivity), Average impedance 6ohms, Minimum impedance 4ohms), stereo amp (25-100w)
, AVR (2ch Driven) - (50-165w)
- Centre Channel - QAcoustics 3090Ci (89 Db sensitivity), Rest specs same as 3050i
- Ceiling - Klipsch CS16II ( 91db Sensitivity, 40watt RMS, 8ohm impedance)
- Surround Rear - QAcoustics - 7000LR ( 85db sensitivity, Power Handling (15-100w), Impedance 6ohm
LISTENING POSITION - 2.87 meters from the LR fronts
Using AURIS BLUME PRO Bluetooth DAC to transfer music via LDAC connection from SONY walkman NW-A105
1. Will I be benefitted in sound quality if I add a power amp??
2. My listening volume is always in minus i.e -30db to -20db, is this ok?
3. If I add a power amp then should I go for Emotiva BasX A7 or Marantz MM8077 according to my AVR
4. Why do these AVR manufacturers never mention their real specs ranging 20hz-20khz power output
Plz help what I need to do
Amplifier Section-
Speakers used are-
