prateekatasniya Well-Known Member Joined Oct 27, 2016 Messages 1,652 Points 113 Location Hyderabad Apr 27, 2022 #1 Looking for Easy to use (wife and mom friendly) Low cost in-ceiling multiroom audio options? Thank you.
theironhorse Well-Known Member Joined Feb 23, 2010 Messages 2,389 Points 113 Location Hyderabad. Apr 27, 2022 #2 prateekatasniya said: Looking for Easy to use (wife and mom friendly) Low cost in-ceiling multiroom audio options? Thank you. Click to expand... 7-8 channel amp from the likes of crown/sonodyne/ahuja connected with sonodyne/ahuja/polk/micca in ceiling speakers, source echo dot RCA out to amp.
prateekatasniya Well-Known Member Joined Oct 27, 2016 Messages 1,652 Points 113 Location Hyderabad Apr 27, 2022 #3 theironhorse said: 7-8 channel amp from the likes of crown/sonodyne/ahuja connected with sonodyne/ahuja/polk/micca in ceiling speakers, source echo dot RCA out to amp. Click to expand... Okay.. I thought something similar. So this is the cheapest option I believe ?
theironhorse Well-Known Member Joined Feb 23, 2010 Messages 2,389 Points 113 Location Hyderabad. Apr 27, 2022 #4 prateekatasniya said: Okay.. I thought something similar. So this is the cheapest option I believe ? Click to expand... asthetically, otherwise ( multiple echo dots clubbed together as a group), you can then play music on one or play "everywhere" and it will do as per the command alternatively a cheap 4.1 system, run wires and hook it up ( cheapest) - 3k + wiring
