Sorry, I such a thread exists elsewhere. I searched all 8 pages of threads in this section but could not find a relevant one. Mods, please merge with another thread if you find it suitable.
These are the same speakers that I have. Posting here if anyone's interested:
BOWERS & WILKINS B&W DM 610 BLACK WOOFER SPEAKERS | eBay
Posting the specs and description again as I need it for online reference (apart from the manual that I have)
BOWERS & WILKINS B&W DM 610 BLACK WOOFER SPEAKERS. Each speaker weighs approx: 18 Lbs. Total Weight 36 Lbs. Measures approx 19.25H x 11D x 9.25 W. In good condition. Gently Used. Minor wear and surface scratches. See photos for details.
- The 600 series has earned a reputation for minimal coloration and musical accuracy in audio reproduction
- Designed by a master of industrial design Dr Kenneth Grange, the cool, dark lines of the 600 series cabinet are perfect partner for contemporary furniture and interior design settings
- The magnetic-fluid cooled tweeter can handle high power levels and deliver true pistonic motion to beyond 20kHz ceiling of audibility
- The 8in bass/mid driver has a low-hysteresis rubber surround with a high temperature voice coil enabling superb transient attack without the usual coloration at high input levels, The result is outstanding bass performance.
- B&W Tweeter technology ensures that the sound remains focused and time sensitive and that the stereo image is presented with unparalleled three dimensional accuracy.
- The strict acoustic requirements of the cabinet have dictated front baffle moldings of extra high rigidity. The polymer has been chosen for its composition and ability to reduce
unwanted resonances to a minimum.
Description:
Drive Units
2-way second-order closed-box digital
monitor system
1 x 26mm high frequency with metal
dome, high temperature voice coil and
magnetic cooling
1 x 200mm bass/midrange with
reinforced polypropylene diaphragm
and 30mm high temperature voice coil
on Kapton former
Frequency Response: 70Hz - 20kHz 2dB on reference axis
Sensitivity: 89dB spl(2.83V 1m)
Nominal Impedance: 4 ohms
Power Handling: 30W - 150W into 4 ohms on unclipped programme
Dimensions: Height: 490mm Width: 236mm Depth: 303mm
Finish: Black Zelda
