Hi, I was searching for small HT setup last month during holidays and tried a few setups including the ones you are looking at.
I bought ELAC Cinema 5 last month and its not at all bad for 150$, not sure whats the price you are getting there.
I tried it for a few days and returned
If you must go with small speakers then prefer to have a better subwoofer, stock sub never feels enough for movies and overall sound presentation becomes really thin.
Cinema 5 Sat speakers are very small and should do a good job in small room for movies on moderate volume, but feels bright as you go high. This may be helpful for movies but not at all for music. I tested these with Sony & Marantz AVRs.
I have also had Definitive Technology ProCinema 400, speakers are about the same size as ELAC Cinema 5 but way better in tonal quality (specially music) and sub integration. These are also sold for about 200$ here. If these are available near you then give these a try if you can.
 I also auditioned Polk TL1600 package, I found them anytime better than ELAC Cinema 5 but again the stock subwoofer was not really that good and changing the sub to a bigger one changed the movie experience completely. These did a good job for movies as well as music on moderate volume.
Hope it helps.
