Subcenter2009
Dear friends,
It can be a tough task to integrate your subwoofer to your home theater system. One may be tempted to turn up the volume on the subwoofer to get heavy bass. This results sometimes in booming and loss or gain in some frequencies as the Front L/R speakers compete with the sub to produce good bass at the same time. It is tough for the Front L/R speakers to fire in Phase with your existing subwoofer. I propose an excellent solution..
Enter: Party speakers that are capable of strong bass.
This method eliminates the need for a subwoofer..thus removing the need for Bass setup as the L/R woofers will always be in phase. Ideally, the input wattage of the L/R should be over 150 watts RMS. So they can play loud without distortion.
Some makers of Party loudspeakers are
Cerwin vega, JBL and Wharfedale Zaldek, Wharfedale Xarus etc.
These should ideally be big towers with Kevlar or Polypropylene woofers.
They should be rated as to go down to 25-30 Hertz.
You don't have to spend a lot of money on a good sub.. The bass will always be in phase.
One good thing is that heavy Bass capable party speakers are usually cheaper than audiophile grade speakers that are much more expensive.
So consider investing in a pair of good party speakers that are very bass capable, save a lot of money without the sub and get clean MEGA BASS.:yahoo::clapping:
hyeah:
Yours,
Subcenter2009
Yours,
Subcenter2009
