Faulty Neutral ???
Kushanava
kolkata
Hi All,
I am in serious discomfort regarding the Power reaching my Audio Equipment.
Problem:
I have my MX spike buster connected to the Wall socket directly.
Even when the Wall socket-switch is off the spike buster has the red light indicator turned on.Red light indicates : L&N are reversed.
I have also observed that the glow on the indicator changes from time to time.
I got my electrician to check the situation ..He traced the problem back to the meter room and into the main power supply.When he checked the same using my MX spike Buster , the red light turned on brightly , much brighter than in my room. He told that the neutral was faulty in the power supply.
I called the CESC.They sent their electrician.They were reluctant to check anything with my MX spike buster and said everything is ok by just using their Test Bulb.
1.Is this situation dangerous for my equipments or is it pretty natural in overhead lines.Is there a way to get rid of the problem?
2.Do I need a Power conditioner/Stabilizer?
Any other suggestions ....
Reversal of L and N can be easily remedied by the local electrician but the change of glow of the indicator seems like a bigger problem. If your spike-buster is working fine then you will have to check the neutral everywhere.
Check the difference in voltage in various rooms across neutral and ground. Use a multimeter. If there is a large difference then there might be a short circuit waiting to happen or some faulty electrical equipment on the line. Unplug everything and switch off everything. Check the lines again. Switch on equipment one by one and when you see the problem reoccurring then you would have identified the problematic equipment (I usually find Refrigerators and inverters the usual culprit in such cases).
If nothing works then get a good servo / stab+power conditioner solution and don't use the spike buster.
